6 channel amp with only 4 RCA outputs from the head unit
perfect that's what I was hoping to hear. Funny part is I have the stuff to do it the opposite way by using the splitter at the head unit. 1m to 2f then running a total of 6 RCAs. Guess that's kind of backwards but sounds like the same thing.
Yeah you can but I was hoping to separate the front 2 speakers from the 4 rear. This is on a boat and the 2 bow speakers can sometimes be annoying to the people sitting up there when things are louder. so with this y adapter plan i think the fader will work properly?
You can do that w/o y cables.
Set it to the 4 ch mode. That will either have 1/2 on it's own and 3/4/5/6 together or the other way around.
Just figure out which two channels operate independently and connect those to the bow speakers.
6
154
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
600
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
743
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
CAPTAINJEH
CAPTAINJEH
Arlington Heights, IL
n2audio
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
