How do I hook door speakers to a amp in a 2004 ford explorer sports trac
  • 1
Bassmaster134
I need some help with my speakers I just recently put new door speakers in they are 6x8 alpine type r speakers with tweeters did all 4 doors! My question is how do I hook them to a amp I have a four channel alpine amp is there a special way I need to hook them up since they have tweeters built in I don't want to damage them! I am new to car systems and don't want to screw them up I already purchased a amp kit and have 50 ft of speaker wire plz use simple explanation for this remember I and new to this! Can I just run sperate wires for each speaker to the amp and use all 4 channels? I just want the best way and explained as clear as can be thanks
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
12
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a...
4
Bassmaster134
Bassmaster134
Beckley wv
Bassmaster134
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
