How much speaker wire?
Moofs
Hey, I recently got a 2003 nissan maxima sedan. I'm getting ready to have this system finished and I want to make sure I'm in the clear and have everything I need covered.
I will be installing components which are running off a 2channel in the trunk. I have 70ft of speaker wire. So cut in half that is 35ft of wire a side.
Is that enough wire to install the front components from amp in the trunk to front doors of this sedan?
Also, from front battery to trunk, is 18ft of power wire enough?
Thanks guys! Just want to double check as to not be screwed over last minute.
Hey, I recently got a 2003 nissan maxima sedan. I'm getting ready to have this system finished and I want to make sure I'm in the clear and have everything I need covered.I will be installing components which are running off a 2channel in the trunk. I have 70ft of speaker wire. So cut in half that is 35ft of wire a side.
I just did this same install on my 03 maxima a few weeks ago. I used a total of about 35 ft of KNU Karma SS speaker bi-wire (both positive and negative wire within a single larger cable), so you should be fine. My power wire run was about 12-14 ft iirc.
Good to hear^^^
Was it a fairly straight forward install? And do you mean 35ft all together for both doors?
(I have the same wire)
They were awesomne man. The components and Coax speakers I shoulk have kept. Theyre amps were pretty nice too. I never ran any of theyre subs...
20
Buck, great idea. I did that tonight, and it actually didn't wheeze like a fat guy trying to run a marathon. I am going to put two windows that...
19
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
If your audio system constantly draws more amperage than your alt produces, it will drain your battery, to the point of the battery needing to be...
14
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
Moofs
Moofs
Chicago, IL
Moofs
