It just doesn't sound right!! Help a newbie..
  • 4
julesMI
Hey all! Hoping you experts can help me figure out how to get the best output from my setup. I'm wondering if I should shell out for a JL CleanSweep, try a rewire, change the sub enclosure, or get diff gear. Here's background info:
I have a 2007 Charger R/T w/ Perf Pkg - came with a good Boston setup, 6 speakers + 276w amp to power all 6 (not sure of watts per chann). I guess there's only 1 pair of full range channels that were powering the rear 6x9s. At least that's what installer #1 told me.
The doors just blew (midrange only) and I replaced them with BA SC60 components (tweets, mids, & passive xovers). Dude who installed said he had to run the SC60s off the full-range channels since they're components, so the only pair of full channels are running both the rears & new doors. Now I've got ZERO bass from rears and my ears are bleeding from too much high & mid (even cranked way down on HU). So, do some more research and pick out a sub/amp/box & had it installed this week - 10" BA G110-4, GTA-802, sealed .56 cuft box. Went with BA again on someone's suggestion that it'll handle diff types of tunes well.
I can barely tell there's a sub in the trunk! (Diff) installer says it's not that loud bc my seat backs are extra dense, but still sounds weak with seatback down. Played around with amp settings per manual and no joy. I don't want some gangster boom, but I can't feel anything. WTF is going on?? Are these installers just BS'in me or what am I missing? Wrong brand or sub? Wrong wiring/channel setup? Try a ported box? Need a 2nd 10" + amp? Add sound processor?
What should I try next? The I was happy with the original OEM system and now I'm in about $700 aftermarket and it sounds like ****. Want to keep the factory HU for wheel controls & so it's less obvious I have aftermarket stuff. I've researched all over online and talked to every audiophile I know, but still not sure.
Help me experts!! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Sorry for the novel, just wanted to include ALL setup specs & problems!
I would change the head unit but if you're set on doing it the hard way than keep the factory deck, get a clean sweep and some new installers
I'm sorry man, I can only imagine how frustrating this must be //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif Welcome and I have no doubt that you will be able to get help from this forum.
Did they use a Line out converter or use high-level signal for the amp input? Meaning are there RCAs coming from the amp or does it have a "speaker level input?"
It would help if you could take a pic of the sides of the amp or tell us what the crossovers are set to, all that stuff. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
This type of controller will work on any amplifier (or specific channel) as it is inline with the RCA connections and functions entirely as volume...
9
923
Mixed Mono has also been around for many years from the 80s as well. Ill use a set of 4 ohm components with a passive Xover and throw in a 4 ohm...
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
12
Sounds like an issue with the programming in your head unit. The designers didn't anticipate the day where the head unit would need to read 700...
julesMI
julesMI
Canton, MI
disturbed471985
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
