JBL GTO755.6 great all in 1 amp
bigblackdodge
JBL GTO755.6
Nice 6channel amp. Strong and clean. Perfect for small stereo builds. Replace front and rear speakers and ad a sub or 2 for a great daily setup. Intended keeping it in my jeep but plans changed.
Mechanical-10
Cosmetic-9
$215.00 shipped bombproof
6-channel car amplifier
60 watts RMS x 4 + 107 watts RMS x 2 at 4 ohms (80 watts RMS x 4 + 150 watts RMS x 2 at 2 ohms)
160 watts RMS x 2 + 300 watts RMS x 1 in bridged mode (4-ohm stable in bridged mode)
optional internal neon lighting (accommodates Street Glow AN9 tubes or equivalent, tubes not included)
variable high- and low-pass filters on channels 1-4, low-pass only on sub channels (32-320 Hz, 12 dB per octave)
bass boost on sub channels (0-12 dB)
MOSFET power supply
speaker- and preamp-level inputs
preamp outputs
CEA-2006 compliant
fuse rating: 30A x 2
4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
19-7/8"W x 2-3/8"H x 12-3/8"D
Wow these r great perfomers. And hard to find! Great price bro glws!
Thankyou sir! Yes it has done nice in the jeep. Jeep wj's with amplified infinty systems have 6 speaker systems. Tweeters on dash, 6x9 midwoofers in front doors, and 6.75 full rangers in rear doors. Replaced all with jbl speakers and ran this amp inplace of the factory amp and really brought music to life with volume and clarity.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
bigblackdodge
bigblackdodge
Morven, Ga
pickup1
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
