JBL Gurus come in
  • 4
I'm in this same dilemma, i just bought a msa1004 for mids, cause it accepts line level input, and i can't afford the ms8 right now, but i'm afraid it will not be enough for the subs amp, and i'm looking for a cheap solution to solve this problem.
Would you put lc2i before or after the msa1004?? it will be only for subs.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
LosIsATool
LosIsATool
Pensacola, Florida
Symon_say
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
