Jbl ms8 accessories
  • 3
I have the hi level input harness and the speaker output harness available to sell. I don't have any of the critical parts you need to get it running such as the display, display cable, remote and maybe the test CD.
Note that JBL discontinued support. and I personally ordered the last display part. You need the display, cord, and headset. I wish you luck,
I suggest you find somebody around you that wouldn't mind setting yours up for you The ms8 will operate without the display once its set up. You just wont be able to go in and change any thing once you disconnect the display. You could always call dude back when you need to adjust it
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
sotelomichael
sotelomichael
Pharr, Tx.
sotelomichael
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
