JBL w12Gti MkII
groundpound4200
Da fuq did I just read?
5,417
Mankato, MN
1 12" JBL w12GTi
Few Cosmetic flaws. One is on the basket (in pics) but does not effect structural integrity. Other is the chrome flaking off the dust cap. Throw it in a 4th order or put a grill on it and you'll never know the difference. The backside of the woofer is in great shape so inverting it will do the trick too!
Description12" Differential Drive® (U.S. patent no. 5,748,760 and other patents pending) Design Subwoofer
Series: GTi
Power handling: RMS 700W Power handling, peak 4000W
Frequency Response: 18Hz ~ 1kHz
Sensitivity: 91dB
Impedance: 3 or 12 ohms
Cone: Kevlar®-impregnated-paper woofer cone
Coil: Dual 6-ohm voice coils
Differential Drive Design (DDD) motor:Yes
Die-cast vented basket: Yes
Mounting Depth10-1/4"
$200 shipped OBO.
shipping included
Why is the peak 4000w and the rms 700w? Never really undrestood that...
How much power can these really take?
My guess would be it's 700 if you're a total arsehole and have no idea what you're doing, 1200 continuous provided you're not playing free-air, 4000 burps if you know what you're doing.
JBL's differential drive motor system acts as a magnetic brake as the coil leaves the gap approaching xmax. These things are about impossible to bottom out and can take alot of power on burps. JBL wasnt' joking, they use a 3 or 5 second burst using two big crown amps bridged, and even running them full bore (which is 4k), they couldnt' cause damage to the speaker...
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
groundpound4200
groundpound4200
Mankato, MN
groundpound4200
