lol my PG RSD tweeters
same boat - melted rsd tweets. were fine unitl the other weeked...been solid for about a year. played them loud for a long time but also had the car in the sun a lot.
i can't see it actually being the sun?? if so then i'll probably end up melting my next tweets too. i had 90w going to each component. perhaps when i tried to blast the stanley cup final on AM radio??? hahaha it sounded really bad.
i can't read behind all the sarcastic comments if the sun could actually be the reason for the melting??? please help so i don't make the same mistake.
can i still mount my new tweets in the 'a-PILLARS' ?? went with Pioneer TS-D1720C to replace.
I bridged my amp (150w/side) to my RSD set, here in the New Mexico heat (pretty hot) for at least 6 months and my tweeters looked fine after taking them out.
Still not convinced? https://gpcaraudio.com/15-dual-high-output-glue-it-screw-it-sub-enclosure/ You can order the box glue and screw kit with...
15
4K
Build currently on hold, waiting on a custom voice coil. The former isnt tall enough for the new setup. On the plus side the motor has 3.25" of...
30
4K
I couldn't hear quite that high back when I had all my hair and Mark Wahlberg was a boy band. 100% Obsolete. Most offerings on the market are...
14
Only problem with the old model I series is they recommend a much bigger box than the current I series. I actually have a pair bnib deciding what...
23
Theride
Theride
NY
RowJoe
