Need a bit of guidance
  • 4
akatreyt
I'm going to be redoing my system and I need some direction on what to buy / best way to spend my money. Right now I have a MRP-M500 on a SWR-843D (don't laugh), I'm wanting to go to a 12' for more bass. There are two options, use the MRP-M500 on my highs and buy a new amp or use the MRP-M500 on the 12. If I use the MRP-500 on the highs I was looking at buying a Kicker 11DX10001 ( thoughts on this?), or does anyone have any suggestions on a good mono amp? Also as far as the new sub goes, I need recommendations. I don't want to go cheap but I don't need a w7, so some nice quality somewhere in between.
Thanks for any suggestions
ok first off the mrp is a sub amp only ,you got a budget ,i can help
ahh didnt think about this, you're right it's a mono amp. I'm looking on spending 400-500 total ... Like I said I want something decent but I don't need to go overboard with it.
ok cool i can do a nice xfl 12 sub new with a american bass vfl 4150 120 watts rms x 4 amp for 460 shipped plus paypal fees ,both new with warranty shipped to your door
Well I'm not looking to buy from forum, just looking to get an idea on what to buy, what to look at.
ok thats fine ,but if you go to the local shop ,you wont get as good as quality for your money .my equipment is top notch competition grade always new with warranty also .i also have plenty of refs here and on other forums too ,i'm a dealer for quite a few companies and a rep for a couple as well.
I appreciate it, but really looking for suggestions at this point.
The kicker amp is solid but I'm sure much better can be had for cheaper. Check out AQ1200
This looks very promising, recommend a good sub to go along with it. Not sure if I need that much bass but never hurts to have I guess ....
Couldn't find the AQ1200 anywhere online, know of any spots to get it?
Also it looks like bass can get had for less than I orignally thought, what would a budget of 350 - 400 get me?
to make the post below make sense, I asked about the mb quart amps, but later deleted it ... not sure why //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
some guys like the new mb quartz amps, i personally dont like any of the new maxxsonics amps ,just not very good. lok at the ab xfl sub ,nice sub for $200
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
146
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
109
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
452
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
348
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
759
akatreyt
akatreyt
United States
Dtrom
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
