Need advice on this ASAP
Id run the amp as it is for now on the sub you have until you save some funds and get a pair of tens and get another sub amplifier. Id look at a CT Sounds CT 80.4 for your speakers . Take a look at a pair of American Bass TNT 10" woofers would be nice on the CT Sounds CT 1500.1. or take a look at the D4 Sounds amp combo package with a single Aero-ported enclosure with a S. Qubed HDS3.2 DVC 2 ohm 12 when they come back in stock
https://www.ctsounds.com/collections/amplifiers/products/ct-80-4d
https://www.ctsounds.com/collections/ct-series-amplifiers/products/ct-1500-1d
https://store.soundsolutionsaudio.c...044-10-inch-600w-rms-dvc-4-ohm-subwoofer.html
https://www.down4soundshop.com/down4sound-jp8-jp84-amplifier-combo/
https://soundqubed.com/product/hds3-2-series-1200w-subwoofer/
I would look for a component set for front stage later on too like maybe like Polk MM 1 6.5 set. Be a nice setup
https://www.amazon.com/dp/B071G8K9SK/?tag=caraudiocom-20
Thats me. You might be able to find a computer repair shop to repair that amp for about $40 bucks maybe??Labor and parts
LOL ok..
Way back in the day we ran HCCA 225's all day long on much smaller alternators (65 amp) with zero issues..
I've been running 1600 rms @ 1 ohm in my 1994 Silverado with the Stock alternator still in service (90 amp)
The ohm load is not the issue here.. the current load a 400 watt amp @ 1 ohm is not gonna destroy alts and batteries just because it's wire to 1 ohm..
Who knows maybe you are right and I've just been lucky since the 90's
Not saying it's not possible but would I recommend it to someone with apparently no experience and on stock wiring/power? Hell no.
Meh. Been there done that.. The examples of the HCCA amps above is when I was a teenager with no experience and on stock wiring/power.. Never seen a issue before at the power levels the OP is wanting to run.
So by your logic.. he can't run a amp that could possibly pull 80 amps at 1 ohm..
But he can run a amp that pulls 80 amps at 2 or 4 ohms?
Could you explain why this is?
Ok.. yes that is my 100% my logic obviously.... somehow.
Deal with it!!
Anyways; it's not as if he never had any problems before. :rolleyes:
Anymore bs/"help" you wanna share?
Deal with it!!
Huh?
"Anymore bs/help" I wanna share?
You're funny lol.. What did you contribute? You can't even back up what you claim..
One more question for you, why come back and bump this thread 2 weeks after it fell off? You thought maybe you could sneak the last word in there and look like you know something? I don't get it..
I could go on and insult you and what not cause lets face it.. you would make it very easy
but it's cool. I'm sure you embarrassed enough as it is..
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
550
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
647
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
918
Slayer16102
CarAudio.com Recruit
Slayer16102
deez283
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
