u don't want words coming from trunk sound like 2 guy yelling in back lol... u can set lp at 120hz to get some higher bass freqs if u play rock music and especially in sealed box, thats where mine is..My kappa 120.9s are sq subs. Should I have my crossover set higher than 80? That's where I have it set.
Any sub will play musicals if ran in Stereo mode,and at a higher HTz range when set within that range.Will it perform and sound theyre best? Depends on how you want to use it and at what frequency/or htz range and what that speaker/subs limitations are,and how you want to incorporate it within your system.I mean Tweeters are not going to play bass Right?They are made to play in a certain hertz range same as mids and mid bass.Read up on speakers and hertz ranges and the like.Im only throwing some bare basics at you, and there is too much information that Id be spending days on to explain asothers would be as well.But if you want Clean and good sound with some decent bass and into SQ,and build the right enclosure and have some decent power to provide the Dayton sub,and for the price and warranty,its really hard to beat out for the money rangeSo these subs are very musical, I looked at some sq subs on youtube and it sounds like you get all the frequencies from that sub. I am so confused now. So that Dayton plays a wide range of frequencies including vocals? And why is that desired if it's buried in a trunk? Please help me understand this part so I can decide on a new sub lol this part just really threw me through a loop!
The HTZ range from 23 HTZ? on up from what I just looked at. Not a bad looking woofer to be honest.If you want a little more lows involved you need to drop the HTZ settings and adjust your gains/ and retune your system to get the most out of it clean enough and within the enclosure and environment its in to satisfy your likings? You may find that another enclosure will satisfy your liking and work well for you without having to purchase another set of woofers.An Enclosure/ proper enclosure is what makes a subwoofer perform at its best,as well as built properly for its environment and its intent and properly suppliedMy kappa 120.9s are sq subs. Should I have my crossover set higher than 80? That's where I have it set.
