Need advice with dimming issue
  • 2
omgitsrage
I have 2 fosgate p2 12s(400w rms each) running @1ohm on a pioneer amp that is 1600w peak and 800w rms @1ohm. not a huge sound system, but my lights dim. it's in a 2013 vw Passat s(no special electronics, no powered seats, no nav) which still has the stock battery with the alternator at 140amps. my lights dim when my bass is hitting, and when I use a volt meter on my battery, volts drop from 13.8-13.9 at normal running voltage to 12.5-12.9 when my system is cranked up. what's the easiest way to fix this? I don't want to hurt my car or it's electrical system with my sound system.
We usually start with replacing the oem battery with the largest agm battery that will fit in the oem location. We also do what is called the big 3.
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
345
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
465
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
810
omgitsrage
omgitsrage
Wichita, KS
macsdad
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
