need around 1200 watts at 2 ohm for around $150
It's not 1500 watts, but the TXA-1000D is PROBABLY the closest he will find to 1500 watts. I just sold one for $160 shipped BNIB.
He can get the TXA-1000D for $199 shipped from the Cadence store.
Other than that, his best bet is to find something used, but he will probably be spending closer to $200-300
Do those put out the 1000 they say they do?
ok since it doesn't look like there is any good ones for around $150..how about a little smaller amp
Anything between 800-1200
Preferably something around 1000 watts.
Around $160
146
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
109
453
348
aaron7114
aaron7114
Arkansas
Anniku989
    May 16, 2024
    May 16, 2024
