Need Help? Let Me know
Keeping the stock amp and sense it is not a bose system you can use new speakers with it. So 4 ohm was the old one hence going with a 4 ohm new one.
Probably but it was two separate outputs of the stock amp so using one would be 4 ohms "metered it and confirmed it" so the kicker went in no problems.
Went to install his fronts today and he got bent out of shape because. I told him first I have to run a new wire through the door for the tweeter from the new crossover. "After telling him that 2 weeks ago" I will honestly say I broke a small side cover above the door "first in a while for me" offered to replace it but he said na. Than he bought a bulk pack of dynamat and got so mad at that he yelled I am not putting any of this crap in continue. Than when he asked how the tweeters would be put in I told him using the mounting cups and maybe a bit of epoxy or some bondo, he said nope pack it all up were done.
Apparently he does not like any kind of glue neer his car or in his car. So no new components went it nor do I think they will. I feel bad and will buy him a new piece but I think the install is done.
Today did a sub install on a 2010 Jeep Patriot. Went smooth and took about a half a day.
Fi Sub
Power wire ran
Used some zip ties after this.
Fuse block mounted and wires covered and ran.
Sub box in place
i'm trying to get a job as a TSA, so i can get free domestic flights, then i'd fly your azz over here in a jiffy and get started on a new install!
Hey Matt... are you still interested in doing my install? I chatted with you on AIM (lemon18190) a few weeks ago.
Ya I have no problem doing your install send me a email or something. Work is busy during the week so that is where a lot of my time is going.
bump, what the fuck dude? where the fuck? huh?
---------- Post added at 04:06 AM ---------- Previous post was at 04:06 AM ----------
6 month vacation? hows it going?
Well did another z another nismo to be exact. So here is the install.
Starting the wiring
Ah the good stuff
Next morning
Guy likes to take pictures
Anything is better than stock but the polks are a great bang for the buck.
Dynamat
Solder the connections
Oh it was COLD went and bought this baby
New panels
Power wire
494
603
872
bigaudiofanatic
Dynamic Mobile Audio
bigaudiofanatic
Dover DE
FreddyNJ
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
