New Headunit opinion
I have about $300 dollars to spend and I want to get a headunit that can play a Zune. I have been looking at the Alpine CDA 9884 and the Pioneer 6000UB. The main thing I am looking for is being able to play my Zune and keep its quality. Is there any way to play the Zune through the USB that anybody has found. And if i cant play it through the USB should i even bother buying the alpine full speed aux cable. Can u even tell the difference between the cable and a standard 3.5mm jack.
The headunit does not have to be one of the two, i am just trying to give u guys some examples of what i am looking for. I have a 2001 Honda Civic EX coupe. Feel free to give me you opinion or any secrets to how you got a Zune to work with the USB.
I like the looks of the new Eclispe 3200, but not sure about the direct iPod hook up.
Check into some Kenwoods as well. Have some nice Head units.
Just picked up one of the lower model ones, but looks nice. Installing it this weekend.
300 dollars can and will get you whatever you are looking for as for as your zune is considered.
The Zune is somethign else.... There really isn't any support for it. Except for the Microsoft SYNC(which will onlt be installed in certain cars). You cant connect your Zune to any head unit through the USB. You can charge the Zune on some of the USB ports, but you cant listen to music though the USB port. You best chance would be for you to connect through the AUX in the front with the 3.5mm jack. Which a lot of head units have.
what ^ said. amp gain setting info, test tones are at the very bottom...
550
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
Kounter Torque
Kounter Torque
Memphrika, TN
Kounter Torque
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
