ADD... not repace wires! Thats what Ive heard anyhow... sooo... dont hold me to that. CHeck my sig. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifIm going to be upgrading my big 3 soon once i get my fuse holder from knukonceptz. So i pretty much just remove the old wiring and use 0 gauge wire in the same exact places the old wires were connected to?
Go here: http://www.realmofexcursion.com/phpBB2/viewtopic.php?t=1101&postdays=0&postorder=asc&start=0I gather from reading the initial post that you're supposed to replace the original wires in order to see the greatest benefit.
Did you even read the tutorial? Add on top of the stock wiring or replace your stock wiring with the new wire if the stock stuff is no good.I dont get why you would add. So you mean you would splice into the stock wiring and add 0 gauge wire? Wouldnt it just make more sense having all 0 gauge wiring then having say 8 gauge (stock) going into 0 gauge?
I only replaced because the original wires were too corroded to be of any use.I gather from reading the initial post that you're supposed to replace the original wires in order to see the greatest benefit.
YES... btw, I got a new + battery terminal today... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifDid you even read the tutorial? Add on top of the stock wiring or replace your stock wiring with the new wire if the stock stuff is no good.
Always add if the stock wiring is in good shape.
