PLZ HELP!!! my amp is overheating, cuts out, and low voltage even on a rf 2500bd!
tomsaccount
For a little while then overheating very quickly and I just got two new subs audioque 12s 3000 rms total and on an rf 2500bd had originally thought it was my voltage regulator but I got that fixed as well as a beefier alternator and I still seem to have low voltage even though I also have hey big deep cycle battery as well. I cannot figure out why and I'm losing especially when the upgraded alternator because sometimes when its running **** only shows 12.9 volts I have all your old age where and did the big 3 with your updates as well but none of that seems to help . I also start off with 13.9 v and then it slowly losing boltage overtime. My last sub I had actually started smoking and birth the coil when I wasn't even playing it loud the point where you couldn't even feel it yet it still burns up i I really need help with this because it has been killing me not having subs I think you guys all know how that feels lol but if you have any ideas or suggestions please leave a comment I would appreciate it so much thank you ~ Tom
see if your alternator belt is the proper size, new alts sometimes needs a snug tight belt along with it. Go to autozone, advanced auto, oriellys and get your alternator/battery run through a load test.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
Can you sell the LOC and buy a head unit for that price that will do all of what both of those things would do?
7
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
If you haven't located the short...reconnecting everything can go the wrong way at the worst time...
26
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
12
651
tomsaccount
tomsaccount
tinley park il
Jeffdachef
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
