Port question
  • 2
Better-Action
give me a reach around
446
SD
I plugged my numbers into two different port calculators and am getting a difference of an inch from the 2.
Not really understanding what's going on here.
The box volume is 3.589 going of the external dimensions minus the mdf thickness, driver displacement and bracing. 16h x 18w x 28d .75" mdf
Tuning is 31hz. 14.5" high by 2.5" wide slot port.
When I punch these numbers into the two calculators, I get a port length of 23.35" from one and 22.1" from the other.
So something isn't right. I would assume over an inch different would really affect the tune, correct? I'm just wondering if I'm going about it wrong in some way and could possibly get some opinions on my course of action.
Hopefully I can get some input on it. In the end If its to much of a hassle, may just switch to Aero ports.
i get 23.35 using my calculator.... as for one extra inch.... i have you at a swing of 30 hz to 32 hz within 3.75 inches..... also, was there an end correction on the other port calculator? that would allow a shorter port.
It could be. So.... basically with the margin of error I'm still going to fall in the 30-32hz range?
Also, the enclosure before the port is 3.589. So I take the port volume and subtract from the overall volume?
So subtract .49 to get 3.099. So the final product would be 3.1 cubes at 31hz correct?
Sorry for the stupid questions. I have built a few boxes but somebody else has always designed them for me. Trying to learn to do it on my own correctly.
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Personally I'd likely go slot ported with the low tuned side of the box and aero on the high tuned side. 6th orders are just big by design
7
Yep. Point A. The last 3/4 of an inch on the exit end of the port won’t count in the displacement though. Take 3/4 off your length. You also have...
842
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
830
Better-Action
Better-Action
SD
Better-Action
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
