Port volume to box volume ratio
  • 4
ggieo
CarAudio.com Newbie
This might be a stupid question but how to you optimize the port volume to the box volume. It appears you can change the port volume as long as the ratio of length to area of the port is the same and keep the tuning. How do you optimize this for the most power output? If the port volume is too small not enough air will be able to move and if it is too big there will not be enough pressure for the driver. I am using your average circular port for this design. Thanks!
It's a matter of port noise - which is created by high air velocity. From messing with WinISD the size of the port makes no difference in sound quality other than creating noise if it's too small. So there's no "optimal" size although I have often seen 12 sq in port area per 1 cu ft net box volume. You'd definitely want to err on the too big side, but at some point you're just making a larger enclosure for no improvement in performance. That's why it's good to be familiar with modeling.
It depends on your power/volume/tune.
There's no magic formula other than keeping the velocities under a certain point.
Aeros with large flares can help with port size and allow for slightly less port area for a specific volume/power at whatever tuning you're at.
But 100fps is my limit with a slot... 115 with an Aero possibly a bit more.
The advice above is spot on imo, so I thought I'd expand on it.
Modeling with your power/volume/ tuning is the closest you'll get to your goals and when it is off a bit you'll be able to see or approximate where you need changes.
My .02
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
756
Yeah I feel like it was a mistake and he meant per sub. I decided to go with 13ft3 net, 186in2, 36hz to be a little on the bandwidth side.
17
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
893
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
595
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
729
ggieo
CarAudio.com Newbie
ggieo
Phoenix, AZ
shredder2
Mr FaceCaser
    Apr 26, 2024
Doxquzme
    Apr 26, 2024
Latest topics
