Post Your Box Specs Here:
I'm finally building my first ported box and it's gonna be a big'un.
5.499^3 including port. I just want someone to check my design before I start cutting.
My my, how this design changed. That port I designed was TINY!
when i designed you that box with 0.5 mdf and a 2 inch diamter port, i used bbp6's driver database to find out that sub's displacement and it was tiny. i can double check if you want. just post the model number and company of the subs.
Sub(s) w/ RMS: DD W6.5/150 each
Amp w/ RMS:Sony Xplod something or other/ Maby 350 if in lucky
External L x W X H:17x15x13
Wood w/ Thickness: MDF-3/4"
Chambers:1
ft. ^3 per chamber (w/out displacements):1.2 ?
ft. ^3 per chamber w/displacements (Vb):i dunno
Tuning Frequency: i think 38
Port H and W/diameter:8x1
Port length:10"
Port extension:n/a
Bracing:n/a
Pic: None for you, needs carpet first
Dimensions i just did for a single Kicker L7 (15 inch):
here you go. someone might want to verify this. but i think it's right. got it tuned to 33 Hz.
box dimensions, dont mind the "port may not fit" message. its a flaw of the program.
port dimensions
the volume displacements if anyone feels like verifying my work
what program is this that you used and where can i get it ???
This $100 over your budget but it checks every other box https://stereointegrity.com/product/bm-11/
10
Yes. Ring terminals will work great. crimp them pretty good. You can hit with solder to make a secure solid connection, and then Heat shrink over...
451
Yes, Winky was triggered and butt hurt enough to start **** when I wasn't even talking to him.
Looking for an inexpensive double din head unit that has the following: Front/Rear/Sub outputs XM Ready Just want some ideas
bcarpenterfhl
Kiss Me I'm Shitfaced
bcarpenterfhl
San Francisco/Hillsborough, CA
bcarpenterfhl
    May 31, 2024
    May 24, 2024
