Power Inverter Questions
The 300W will draw more than a 140W as the components are large in scale to handle the apower differenc . With this said that "more power draw" could me Miliamps difference. some companies offer tech spec, not sure if you will find a resting amperage draw.
while the electronics have a higher current rating, it doesn't mean they need more current to operate - it just means they cost more to build. any difference would be negligible.
yes, the inverter only outputs what the load requires.
I sure did. Nostalgia is what brought me to this website, wondering if it still existed. I can still name some of the people and describe some of...
223
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
585
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
428
TravG
TravG
Canada
keep_hope_alive
audiobaun
    May 19, 2024
    May 19, 2024
