Power wire
  • 6
If lowes does have it, its porbably stiff as hell.
you could prolly find a local welding supply shop that carries the wire.
It really depends on the load going through those cables from the block. But as stated, 1/0 would be the safe bet, 2 gauge may work as well. Most 2 gauge is good for 200A of total current draw. Add up your amps fuse ratings or manufacutre's listed max current draw and that will give you a better idea
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
8
Oh, total opposite. i play with storage bins full of wire scraps from past installs for fun. I hoard decent grade wires from audio homies...
6
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
blowsoot
blowsoot
Los Angeles, CA
knukonceptz
