power wire
  • 3
I have wired just under a dozen amps myself and I have never used anything other than multi strand copper wire. On my own systems, I first used Phoenix Gold wiring. After a few months there was blackening (corrosion) around all the power and ground wire connections. I then switched to using Street Wire power cables and I have never seen a speck of corrosion or wire blackening since. I think that as long as you stick to a decent name brand of wire, you should be alright. I think you said that you knew about guages so I won't get into that.
The only difference # of strands makes is flexibility. I found some 2 ga welding cable at the hardware store the other day that was like $0.80/ft. that would work just as well as the $3-$5/ft stuff. Like nate said though, corrosion might be a concern in the long term.
Originally posted by n2audio:The only difference # of strands makes is flexibility. I found some 2 ga welding cable at the hardware store the other day that was like $0.80/ft. that would work just as well as the $3-$5/ft stuff. Like nate said though, corrosion might be a concern in the long term.
true true
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
8
Oh, total opposite. i play with storage bins full of wire scraps from past installs for fun. I hoard decent grade wires from audio homies...
6
976
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
liwaj79
liwaj79
fremont ohio
ramos
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
