Proper power for 2 SQ2200
So at the moment i have a duralast gold battery under the hood and an optima yellow top in the rear powering a single SQ2200 and an audiopipe apsm1200(4 channel). This is charged by a 270 Amp DC Power alternator. When playing right at clipping my voltage drops to about 13.5. I have it wired at 0.5 ohm and Sound Qubed has told me that this will cause the amp to need twice as much input vs 1 ohm. I have a 2nd amp but im worried about putting it on there because i dont know how well my electrical will hold up. I was going to bridge the two amps at 2 ohms so each amp sees 1 ohm. I have my eyes set on an XS Power D1200 which claims it can provide 3k watts as a secondary battery. Will my optima and the xs power be enough to stabilize the 1st amp at a steady 14.8? And if the second amp is strapped will it be able to atleast keep voltage about 14?
Only one way to find out. But personally i would by at least 105ah battery for your secondary. If you cant afford the xs d3100 sams club and others sell rebadged dekas for 170-220 each. These budget batts will work just fine.
well, XS power is in their own category, much more powerful then a conventional AGM battery. Hence the price premium.
Im definitely going to shoot for a D1200 and see how it fairs. If i cant stabilize at charging voltage then i'll just buy a second.
I would do as much as you can afford when you place your new speakers in if you cant do it all now. you can always pull your door panels off later...
466
Someone was telling me I need to have a battery isolator and some kind of DC to DC charger or do I run it directly off the main battery post pos...
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
418
Jkidd288
Jkidd288
Greensboro, NC
Jkidd288
    May 24, 2024
    May 23, 2024
