PS8 - General Guidance
  • 2
fly_marlin
So after initially playing with the PS8 in standard mode, I'm at a point where I need some help. First, a few problems:
1. Alternator whine that previously didn't exist - Arc support suggested I run a wire from PS8 signal ground to chassis of the HU. Hoping this fixes it.
2. Can't get the PS8 to connect to the software consistently. Each time I have to repeatedly take out and put the USB cable back into the PC. Eventually it works.
More generally, I need help with this:
1. To center the front stage in front of me, should I not delay the left speakers? Doing so didn't do the trick, but delaying the right side seemed to work pretty well, though it seems that my left ear is hearing most of the music...could be just me though.
2. What adjustments do I do to bring the stage up and out toward me? I'm guessing this has to be done via EQ and with higher frequencies, not sure which though.
Thank you!
I'm running passive. Can't figure out if my x-overs can do active. Hate to not use them, cost me like $300 //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif Didn't think I'd get a DSP back then. Anyway, can't I still just do this on the left side? You're saying turn down everything at and above 3.5 kHz?
Do you know how to bring the stage up and forward toward me?
time alignment is not the same as volume. Time alignment is usually only needed when you have an amp or multiple amps, and one has a delay. I...
Looks like it's wire it either 4 or 8 ohm 🤔
4
845
Okay. Thank you so much! I will run individual power / ground wires to each amp. If the front of the car has no dedicated spot for tweeters, what...
876
You will need distribution blocks for the amps I would run 0 gauge to the blocks and 4 gauge to the amps. For the head unit I would us one that...
I think what you're asking is the head unit's physical size as in will a new one fit where the old one is mounted. - If so, head units are...
10
fly_marlin
fly_marlin
United States
fly_marlin
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
