Re-wiring a car
  • 6
MoZ
So My jeep has a stock amp and the amp is kinda dying. I talked to the local car audio shop and they said that they could bypass the amp and re-wire the car from the head-unit. So i was wondering if that would be better just re-wire the whole thing from the deck or buy another amp for a little more power?
Right now i have 4 6" DS Kicker speakers and a Sony head-unit.
If I do re-wire it, what kind of wire would be good?
Rewiring the speakers to be powered bu the HU would be cheaper, but would result in lower quality sound (most likely). Buying an aftermarket amp would be more expensive but would result in better sound (most likely). It depends how much money you want to spend.
You can use any wire, it's all the same. Just find some speaker wire on crutchfield or sonicelectronix or something.
Yeah, i wish it was nice but its a 96 and i figure the HU would give out more power than the stock infinity amp?
What amp would be good around $150 for 4 6" kicker DS speakers?
MRP-F300 Alpine. The unbreakable amp. If it is a 96, you can just bypass the amp under the rear seat. The radio has hi level output to the amp. It will work just fine.
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
620
If the original plugs have been cut off, you may want to get some from a wrecked car. You could also search online for a radio pin-out for said model.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
147
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
541
MoZ
MoZ
Salt Lake City, UT
Imtjnotu
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
