Real noob at HT... Can i use 10w3v2? Amps?
I noticed most sites have actual HT subs. Been looking around at these plate amps and such... no idea what im doing. I have 2 10w3v2's sitting in my room that i had used in my car and no longer need them in there (since i got my 18xxx //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif ) Anyways, i was looking at this amp:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=300-794
First off, the question is CAN i use my 10's for HT? I have no idea what im doing here and have been searching forums but every post seems to already know something that I dont about HT. So i will be blunt. I have a big Peavey guitar amp and a little Crate here... like i said i know nothing about HT amps so im wondering if its possible to use them even? I deff need some help on this stuff. Been into car audio for awhile and i took out my 15w0 and 10w3v2's. Dont want to sell the 10s really, i love them. But i have no use for them unless i can hook em up to my computer //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif . I have an upgraded sound card and everything... i have a mono sub RCA out aswell. Really just a noob at this and would like to bump in the basement //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
What about the whole guitar amp version? Would that work at all? Or would i have to buy a plate amp... i have a acoustin authority sub on my computer already. If i opened it up would the amp in there be able to push my 10's?
Why? I thought it sounded like a good idea since it would be free...i dont use my guitar amp. But like i said, i know nothing about HT so... ill take your advice. Theres that amp i posted on the first post for $55 on ebay. Was thinking i should get it. I just run regular speaker wire that i have sealed into my box already to it and and rca to my computer? plug it in and its good? Sounds too easy
2x D6 wires to 3 or 6, right? You might be ok with one of the plates off PE.
Where is this RCA out you mention, on a receiver or the sound card? I dont think I've seen a sound-card with an RCA unless you have one of those external beasts.
Run that out to a receiver, a budjet 5.1 off ebay will do fine for fairlyl cheap. Build an enclosure complete with plate amp and bump away...at least thats what I did.
Well i built my computer... so i put the intel D915PBL motherboard in it... its onboard audio so... high definition 8-channel... it enables 7.1 surround //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Receiver? And again im back to whats wrong with the big ****in ass peavey amp i have? Couldnt i just take the amp out of it basically? I have my 10's in 2 sealed enclosures all ready to be hooked up so...
Home audio is vastly different from car audio. Unless you have prior experience, I would not recommend building your own sub enclosure. Acoustics in a room are very different from acoustics in an automobile. Speaker companies spend lots and lots of time on research of how to get a flat frequency response with their subwoofers while maintaining decent spl. If you just want loud, you can do it. But if you want a flat response and good SQ, it's not gonna happen w/o some research and a good design. Hope this helps.
The onboard sound is only going to act like a headunit and feed the receiver. Your still going to need something to power the sub .If your peavy can do it at the right load, go for it. I just read another thread showing how a guy made a tig welder from an alternator...necessity is the mother of invention bro. But I dont know what you would do for your satellite speakers. Are you replacing a sub from a current computer speaker system or are you going DIY?
If you model it, achieving good SQ with DIY enclosures is extremely possible...absolutely nothing fundamentally more difficult with building a subwoofer enclosure for the home than a vehicle.
If anything, accurate modeling of the vehicle environment is far more difficult.
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
SwaveY
Banned
SwaveY
Slippery Rock,PA
SwaveY
