Remote start+5 speed
your insurance will not cover yoiu if you have a remote start on your car. It can be done. you have to cut the clutch safety cable so that the car will start.
I seriously WOULDN'T recommend rem. start on a stick.
Too many things could go wrong that wouldn't be covered by your insurance; but yes, it is possible.
Possible = yes, hard to do = no, safe and intelligent = NO Don't do it my brother seen it done and the results that come from the one time you forget to leave your car out of gear. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeah its dangerious, but its also very easy.
I ALWAYS turbo time my car when I get out, so its never in gear when i start it. Even if I have the SLIGHTEST doubt I ddin't leave it in neutral/turbo time it I won't start it
2 brands that WILL do it safely...
1 : Compustar
2 : AstroStart
2 brands that WILL do it safely...1 : Compustar
2 : AstroStart
Clifford used to make one as well. I have also seen plans for a conventional remote start system with a series of reed switches to convert to a "safe" manual autostart. Dude didn't say anything about buying a new system, but rather use the codealarm he allready has. That's why I said don't //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Straight from every compustar owners manual ( I have 4 models in stock looked through them all ) in the safety precautions. And I quote
3. For manual transmission vehicles
If the CompuStar system is installed in a manual transmission vehicle, extra
precautions are required because the CompuStar does not monitor the gear shifter
So what makes it safe for manual transmissions ?? Just because the company says so ?? My shop will not install a remote start on a manual transmission equipped vehicle for liability reasons. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Allrighty just checked out the astrostart, same thing . While they both say they are compatable with vehicles euipped with manual transmission. THe only safety feature either offers is the e-brake switch. Which is a common feature among other systems as well. He!! in dash monitors have the same thing so dumba$$es don't watch tv while they drive. Once again I am back to asking. What makes these any safer ???? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i wouldnt recommend it...me and my dad made my car so that it will start without the clutch being pressed in...and i was going to do remote start, but too many people said it was way too dangerous..
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
12
341
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
8
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
baggedmazda
baggedmazda
Lincoln,NE
95Eclipse
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
