Sd3 rms?
  • 2
The Camry
Hey, I Try.
Hey all. Been a minute. Anyone have experience with the sd3 lines actual rated power? I know SA usually under rates their rms recommendations but it being a shallow mount and having limited excursion. I'm wary of putting too much on them. Obviously correct crossovers are useful but im more concerned for thermal limits.
I can’t say myself when I had an sd3 I had it on relatively low power but have seen some posts talking about it bottoming out with the underhung design the coil is short
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
No issues there. The amp will output depending on the speaker's impedance rating. Are you using a component x-over or is only the tweeter with x-over?
Deff a beautiful constructed sub. The best thing about as well, they do perform very well too and have excellent C.Service and even Tech service...
21
4K
The Camry
Hey, I Try.
The Camry
Western Oregon
MattinMO
Decebal
    Jun 10, 2024
