Seeking for the right AMP
  • 3
First of all why are you running CVX's in a sealed box? If you don't have room for ported then run one of them. Also need to know what voice coil config they are. Dual 2 or dual 4 ohm? This is important because dual 2 will have a final ohm load of 2 ohm or 0.5 and dual 4 will have a final ohm load of 1 ohm or 4.
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
Hi my names Vick and I am seeking to compile a list of reputable car audio / security systems that do professional work, take pride in their jobs...
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
jsnka8
jsnka8
Miami, FL
jsnka8
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
