Silverado - Adding OE NAV
  • 2
Mossyoakglock
CarAudio.com Newbie
I have a 2008 Silverado with the Bose system and the 6-disc/MP3 radio.
I have a GM OEM NAV radio for the Bose system that I am trying to install in my truck for mainly the backup camera. I had the unit flashed to accept my VIN and have everything connect except the backup camera (purple plug, black plug, radio antenna and GPS antenna).
The unit powers on and all lights work and it displays the clock like it does when the radio is off. But, the unit will not turn on. I've tried disconnecting the battery, resetting the CANbus but nothing works. Has anybody every installed factory NAV on a non-Nav unit and got it to work?
Any suggestions as to why it's not powering on. The company that flashed the radio said it power up and worked just fine on their bench.
you may want to check out a gm specific forum. most of the folks around here that have your same vehicle (or similar) have aftermarket stuff stem to stern
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
565
Very true, however I also am having trouble finding a speaker that would appear to fit the bill, several have tweeters and a woofer, but not a sub...
52
7K
I have a nissan and i put mine on a switch that has my aftermarket reverse lights.worse case scenerio,u can do that.i just have to flip the toggle...
9
This is not subjective. Matching the resistance of a given speaker to the amplifier in use is part and parcel of the function of the system. If...
18
Mossyoakglock
CarAudio.com Newbie
Mossyoakglock
youdoofus
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
