Silverado DDZ build
Did some Illuminati shit that I learned in geometry class to find the center of the circle
Mid fit
I used a hole saw to cut the tweeter mounting hole. Mistake to leave the mid mounted in the baffle. The edge of the blade bit wrong and skipped onto the cone of the mid. Tore through the dust cap and part of the cone //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Now I got a stencil for future reference..
Here's everything mounted in the door. Probably going to bondo the edge of the plywood layers and then wrap with fabric
http://i1369.photobucket.com/albums/ag209/adulbrich/IMG_20150829_131643_937_zpspf9dqyxk.jpg[/
Kinda impressed Big Homie ! They would have really benefited from you finding the router I think though.
Great systems = 80% skills + 10% beer + 10% equipment
there is some great equipment here
beer is pretty cheap and easy to get
skills...well I will leave that alone
Fair enough. Im def a function over form guy.
Thats my prob ! I want best of both and thats pretty hard sometimes but I keep working at it ! OP sounds like he has got it all down on tech side atleast alot more than I do esp for his age and the implementation of the plan will improve as he redoze it 300 times lol plus once you get it playing you can always make it look the way you want it.
I had to space them out from the existing speaker holes. I think stock was 5 1/4. Otherwise, it wouldn't fit
i could swear all our trucks were 6.5 in the doors but they have tiny mounting diameters on stock speakers or something, it was hard to fit a 6.7 in there.
This is the biggest build I've ever done, so it's a learning process
He s only 17 give him a break! The skills will come along. Off to a good start at least.
Thanks man
Oh, I didn't realize.
GREAT JOB OP
Yep
Basically
Yeah, will most likely re-do it again
I'm thinking about covering the box with mirrors..... //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
I can go take a picture of the hole with a tape measure. Definitely smaller than 6 inches
Well speaker might be 6.5 but magnet is like one off a 3.5 so either you gotta space it out or grow a pair and cut it out lol I tried to Do everything but cut it out and was never happy with the sound or looks of it so I cut the ***** !
Its better you dont.. Replacing a panel is cheaper then welding or replacing a door.
I dont like cutting my truck up and i drive a 2000
Sent from my draconis using Tapatalk
Yeah, I agree. My truck is a lot more expensive than my car was.
Plus, I've only got one vehicle now
I'd rather not cut the door right now if at all possible
I wouldnt cut that truck either I gotta say lol mine is old 96 so its ok and I cant really resale it for enough that that would be a deal breaker and also I only do things I got a plan B for as in being able to put stock ones or atleast replacement speakers if I did want to sell it. Except for the two 3 inch holes i drilled through the bed floor for electrical in tool box and even then I could put another tool box back in and cover them up. Ha Ha
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
643
Very true, however I also am having trouble finding a speaker that would appear to fit the bill, several have tweeters and a woofer, but not a sub...
52
7K
I have a nissan and i put mine on a switch that has my aftermarket reverse lights.worse case scenerio,u can do that.i just have to flip the toggle...
This is not subjective. Matching the resistance of a given speaker to the amplifier in use is part and parcel of the function of the system. If...
18
adulbrich
Olive oil un-virginer
adulbrich
Ames, Iowa
adulbrich
    Jun 1, 2024
    May 31, 2024
