single vs dual vioce coil
The only advantage that you get with dvc is the wiring flexibility. Say you have a 4 ohm dvc, you can wire it up as 2 ohm or 8 ohm. With a svc you get what you paid for unless you have more than one sub.
it depends on the type of install.. what amp u using and how many subs... and what is their resistance (check with Amp )
Dual voice Coils give you more options on installs...
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
652
nandoman
nandoman
orlando
300m_on_xxx
