Sub problem
  • 2
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
646
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
693
That does sound similar to what mine does, I'll take a video and post it this weekend so you guys can weigh in.
23
5K
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
235
Johannes aero
CarAudio.com Newbie
Johannes aero
Vadsø
1aespinoza
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
