Sub wiring question
Just to clarify, are you talking about the power wire from the battery to the amp, or the speaker wires from the amp to the sub?
If it's speaker wire check out this article:
Speaker Wire
You don't need massive wire, but since you're probably using short runs you might as well just get big wires for a few extra bucks for the coolness factor and peace of mind.
If you're talking about power wire that's another story.
Speaker Wire
I'm talking about sub wire
Alright so I try to wire my subs to 1ohm and I can't cause the 12 gauge wire I'm using won't let me fit them both in my sub terminals so should I go maybe with 14gauge wire remember my subs are soundqubed hds312
Not sure I make sense of this. I've seen the terminals on those and you should have no problem at all sticking 2 12awg wires in one. Maybe it's thicker than 12awg?
na is 12 gauge what I have but Ima try it again
A little DAP will do ya, drill, feed & seal, done.
714
two d2 subs can be wired to .5 or 2 or 8 ohms not 1 heres how to wire subs...
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
Having to adjusting the sub input sensitivity depending on the music, would be reason enough for me to go with the RCA cables. It does seem odd...
Repoman79
Repoman79
Nj
fly_marlin
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
