Sub won't hit higher notes
RWhite
I have 1 Nvxvcw122 dual 2 ohm hooked up to a hifonics brx1200.1D at 1ohm. The system hits lower notes pretty well:veryhapp: but when it comes to higher notes it doesn't even play or barley at all.//content.invisioncic.com/y282845/emoticons/rage.gif.0ad8a6e5565b5fddce406566fdd05149.gif any help?
Could also be a phase problem with the sub where it interacts with the full range speakers at the bottom of their range.
I had that problem once and thought my enclosure was the problem. Or bad door speaker installation or a number of other possibilities.
I let it go on for months b/c I didn't want to do the redesign/rebuild. Then one day it dawned on me. I just flipped the phase switch (dial actually) on my sub amp and my mid-bass came to life...
And I felt like an idiot.
Thats Great man. Its always nice to hear what the actual culprit was in these threads. It deff helps the next individual (y)
220
550
RWhite
RWhite
Indio, CA
Jeffdachef
