Sub won't hit higher notes
RWhite
I have 1 Nvxvcw122 dual 2 ohm hooked up to a hifonics brx1200.1D at 1ohm. The system hits lower notes pretty well:veryhapp: but when it comes to higher notes it doesn't even play or barley at all.//content.invisioncic.com/y282845/emoticons/rage.gif.0ad8a6e5565b5fddce406566fdd05149.gif any help?
Could also be a phase problem with the sub where it interacts with the full range speakers at the bottom of their range.
I had that problem once and thought my enclosure was the problem. Or bad door speaker installation or a number of other possibilities.
I let it go on for months b/c I didn't want to do the redesign/rebuild. Then one day it dawned on me. I just flipped the phase switch (dial actually) on my sub amp and my mid-bass came to life...
And I felt like an idiot.
Thats Great man. Its always nice to hear what the actual culprit was in these threads. It deff helps the next individual (y)
8
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
266
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
429
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
532
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
851
RWhite
RWhite
Indio, CA
Jeffdachef
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
