Tuning with a DMM... couple questions
  • 1
sothavok
Nebraska
i have Hifonics Brz 1700 watt mono D sub and 2 rockfordfosgate p3's2d12 at 2 ohms
my subs are 500 watts rms each
im setting all my gains currently with a DMM
couple questions
i have a line driver i set that independently the same way as amp correct?
as for my amp does it matter where i set the x-over freq. i know not to have any bass boost
where should my bass dial be?
Which test tone should i use for my subs and which tone for my tweeters that are JL C5 tweeters
and finally from my calculations i got 31.6 AC volts (for my sub) i want to read correct?
SQ is subjective. If you're looking for the flattest possible response curve, usually sealed will give you that in a car. Porting is more...
5
sothavok
sothavok
Nebraska
sothavok
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
