Tweeter location question
Jimg
CarAudio.com Regular
217
13
Truck will be a Toyota tundra
6.5 inch in the door. On the tundra the factory speaker location is a little low in the door.
My question is where should I place the tweeter? I thought I was going to put them in the sail panel. But after doing some research and watching YouTube videos This is going to have almost two feet in distance between the tweeter And the mid.
It is also going to put the driver weeter real close to my left ear compared to the other speakers.
I have seen some videos where they are putting the tweeter in the kick panel and aiming them up to the center of the headliner.
Is this something that is just trial and error and have to try multiple locations and adjustments to find out what works best with the total setup?
I plan on running a basic two way setup, up front ,,,no rear fill
Dsp will also be used for adjustments as needed.
Just wanted to get some ideas before I just put them in the factory dash location firing off the windshield
i have an Accord, put mine here, so my knees dont block them and theyre as close to the mid as i could get them. mids right below them in the stock location. sounds really good but my deck has time correction
35584
if you have a clear path that is closer to equidistant the better, depending on the drivers off axis response and assuming legs and other **** aint in the way
thanks for the responses, I have an Alpine iLX-705D ( iLX-507 in the US) which has some inbuilt time alignment and fairly advanced EQ.
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
280
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
808
Tons of options in that budget, including the cost of installation,
10
817
Jimg
Jimg
    May 18, 2024
    May 16, 2024
