upgrade from IDMAX???
there is no such thing as upgrading from an IDMAX
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
get another one
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
actually im not sure, i guess i have to take the subs outta the box to find out... might do that tomorrow then
if you have a DMM you can just probe the terminal of box or the amp's speaker output terminal to get the final ohm load and figure out the vc config.
get another one
x2
Certainly a tough decision on upgrading, I would vote for just getting another and knowing you got pretty much the best out there. If your set on changing up there are some good suggestions, maybe look into the JBL WGTi also.
yay i have an idmax.... just got it two days ago. I never thought i would own one as it was my dream sub. Dreams come true and it really is the best overall sub i have ever heard/owned. I was thinking about your upgrade question earlier.... "how much better can a sub be?" I think the answer is there isnt one... you will just have to keep buying more idmax's if you want louder or maybe drop down to the IDQv3 if you want cleaner. Honestly though i have a 10" idqv3 and the max sounds just as good if not better.... sooo with that in mind i dont think you can upgrade my man. Congrats you have graduated from subwoofer investments
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
642
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
767
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
Are you planning on upgrading the alternator and add extra batteries?
853
happyb
happyb
kaneohe, hi
Papermaker85
Decebal
    Jun 10, 2024
