Upgrade questions
  • 4
Wipster
UK
Hi all,
Looking for a bit of advice from the people with experience regarding speaker choice for my car, my stock ones blew //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif literally and physically. I know this is a very expansive question so let me give some details to narrow it down a bit.
The range I am looking in is the 4ohm 6.5" speakers, reason for this impedance is I don't have an amplifier so I need to be able to drive from the head unit (KDC-W8534) being LOUD isn't too important too me I'd much rather have good sound quality at my normal listening levels.... or is an AMP just considered a MUST?
The head unit outputs 30W RMS, so I think I need a bit of headroom in-case down the line I do decide to get an amp so I am also looking in the 60W range...
The music I listen too is a bit of a range from metal to dubstep so it can be quite bassy, to that end I am changing my fronts from 5.1/4" to 6.5" (space permitting) so they need to be ok with lower frequencies, probably not going as far as a subwoofer... I like my boot space.
I am also not an 'audiophile' so there is a cap to my budget which is probably around £50-60 per speaker pair.
Sofar I have been looking at the Alpine SPG-17C2 but not knowing much on the subject and being a bit of a stickler for stats I cant make my mind up.
What would you recommend I look into?
Thanks for taking the time to read this,
Wip
If you truly have 30W rms, then just about any comp set that has a sensitivity rating of 90 or better would sound pretty good. I have Focal 165 A1 comps running off my OEM HU which may put out 15w rms (BIG may), so lets say 10W. These focals have a rating of 91, and they get plenty loud for me, have the detail I want, good seperation and depth to the music. I have deadened the front doors fairly well, have good mid bass response as well. Here in the US, my speakers list for ~$280+ USD. You can find them used for less on most forums. Some will say the tweeters are harsh, and they can be, but I have no real complaints about them at all. You should be able to tune them a little with treble/mid adjustments on the HU, but I'm not familiar with your HU. But try and listen to as many different brands as you can as speaker selection is truly a personal preference.
Mb quart and hertz audio are the first two I can think of that I have listen to personally that stand out as great sounding speakers but both where component sets I can't see the co-ax version's sounding much different other then tweeter placement
Well the specs of the unit say the internal amp can do 4x50W Peak, 4x30W RMS I guess I need to take that with a pinch of salt but in that area. Thanks for the tip about the sensitivity, there I was thinking awww a few dB off wont matter... after reading more about it its become clear that it defiantly would. The difference between the Alpine and the Hertz is 4.5 dB, I guess thats why the peak power of the Alpines are so high because they need over double the amount of power to get as loud.
Read a review of the Hertz, search for DCX165, and it says they are 3.2Ohm not really 4 not sure if this will overheat the headunit kenwood seemed to think it might cause damage bellow 4.
Great advice sofar, thanks keep it coming //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Edit: Having a gander at DLS 126's anyone have any oppinions on them?
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Thanks for the reply bass addict. I am sure with ya'lls help I'll get it tuned up. Audiobaun has been a huge help. He basically linked everything...
50
6K
Thanks so much guys. Talked to crutchfield support with the same question and although they likely don't know everything, and sometimes, salesmen...
The big 3 in 1/0 redoing power and grounds in 1/0 should be good for what you're running...I'd start there and if you still have issues I'd look...
This is really the only correct answer since we have no way to account for the other variables. If you're not talking about the same exact...
Wipster
Wipster
UK
Wipster
