Viper 791 Help
  • 4
matt_attack
I just hooked up the 12v constant wire and my car wont start. I was doing just this one to make sure it would work and it didnt. Do i have to hook up all the rest of the wires or did i hook it up wrong? The constant from the battery went to the brain and then back to the factory constant. I also hooked up the ground wire cause i thought that might be the reason but its not. I left all the other wires factory. Do i need to run the starter through the alarm to get my car to start even though its still hooked up factory?
Okay, I'm trying to picture what you did from what you said. Did you cut your factory constant power wire to connect it to the alarm? Which constant wire did you hook up, the small red one from the brain or the large red ones from the relay pack? Please explain EXACTLY what you connected, what you cut, where you made your connections, and what kind of vehicle you're working with.
okay so wait what wires did you hook up besides the red one??? and what kind of car is this. we need more info to really be able to help while not there with the car
and why did you run the constant from the car to the alarm brain then back to the car?? the alarm takes power from the car doesnt feed it back to it. or at least shouldnt if hooked up right
피크를 사용하지 않을 계획입니다.
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
250
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
261
11
498
matt_attack
matt_attack
Southern Cali
zfactor
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
