voicecoil wiring options
if i had a dual 1 ohm sub can i break it down to .5 ohm or what would be the next lowest ohms setting i can run it at?
A single DVC 1ohm per coil subwoofer can be ran at either .5ohm (coils in parallel) or 2ohm (coils in series).
quick question.
My Amp has 4 connections for the speakers.
Now my subs are 4ohm DVC wired down to 2ohm.
Do I just connect one sub to + - and the other to the other + - pair since it's a Class D amp and supposed to be bridged internally?
The manual is of no help.
yes one sub to each set of terminals (the reason they put 2 sets is for wiring ease they are really the same terminal) and the amp will see a 1 ohm load....
quick question.
This may be a dumb question, but going from a Mono amp that is 2 ohm stable, how do I keep the system at 2 ohm? I see the pictures have 1 sub down to 1 ohm, but not at 2?
If it has to be brought down to 1 ohm, will the sub have more output?
I'm not good at the technicals. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
~Levi
anyone???
wire 2 pairs of the dual 4 subs in series to get a 1 ohm load, then wire both pairs together in series for the .5 ohm load. ms paint coming in a minute, i always get my series/parallel confused to it might be backwards
so basically all pos and all neg are hooked together.
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
237
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
4
470
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
370
paikiah
Wangaholic
paikiah
Seoul, Korea
tomi
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
