What rms rated and peak power rated 6X9's can I use on my MTX Blue Thunder Pro 400x5
  • 3
89Eldorado
Houston
Can i hook up 2 pairs of 6x9's to my MTX Blue Thunder Pro 400x5 if so how much rms should my 6x9's be so i won't blow my tweeters on em and also, can i hook up a pair of polk audio db351 on this amp too or should i hook em up to another amp and how many watts on the amp to push em.
1 w rms..
im not that slow man
@dragonrage... yea but i mean i dont want my speakers to clipp and have my tweeter blown i already did that to my old speakers and i dont want to do it on the new one im goin to buy, what range of wattege speakers would you recomend so i would send clean signal to them without clippin i heard its better to overpower the speakers a bit over underpowering them...could i hook up my db351 on this too or should i get a different amp
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
No issues there. The amp will output depending on the speaker's impedance rating. Are you using a component x-over or is only the tweeter with x-over?
Deff a beautiful constructed sub. The best thing about as well, they do perform very well too and have excellent C.Service and even Tech service...
21
4K
89Eldorado
89Eldorado
Houston
89Eldorado
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
