What wire to run from amplifier to subwoofers??
  • 4
tgraham09
I'm putting in a RF T1000-1bdcp hooked up to 2 12" kicker L5s (if that matters) 1200w rms. This is my first amp install on my own and the amp kit I bought didn't include speaker wire. I asked a friend what size wire to use to run from the amp to the subs and he said 16 or 18 gauge was fine. I just find this hard to believe because I don't understand how all that power can be properly delivered by that size wire. I also find it hard to believe because the inputs on my t1000 look like their designed to receive a much bigger wire.
Please let me know which size speaker wire would be best. If 16 or 18 gauge is the right size, someone please explain to me how it can be so small.
16 is fine...Hell i ran 16 then 14 and ended at 12..No difference whatsoever...I would say get 12-14 though if you gotta buy some..If you got 16 laying around use it, if it would make you feel better double it up if you have enough.
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
266
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
758
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
952
tgraham09
tgraham09
Linesville, PA
disturbed471985
    May 31, 2024
    May 24, 2024
