whats a better sub?
You are comparing a toyota yaris engine to a v6 mustang. HDC in every way. Should not even be compared in the first place. The HDS 200 series is a better match for the mofo, even then the mofo is pretty outclassed.
what would be a good amp to go with the soundqubed? when it says 1500 rms is that true? only because mofo says 1500 and i have a feeling thats not true. any other subs run better with the price range of 300? if i were to buy online any suggested websites?
Hdc3 can take up to 2k-2.5k easy...
Sent from my draconis using Tapatalk
Why don't you show me 2500W 50hz sine wave clamped into one, I'll bet you it doesn't survive to the 5 minute mark.
Omg enough with that 50hz sine wave Bs!!! No one drivers around playing a 50hz tone.
We clamp over 3k per nsv3 coil daily! That's a 3" coil. Yea it can be done. Yes your an idiot pulling that 50hz sine wave card.
I'd agree, clamped, they'll be lucky to take 1500 on a 40-50hz sine wave for more than a five minutes, but on a 2.5k + normal rise then they should be fine with a clean signal.
Prly a burp in which case who cares. If u can't play music, no one interested
You sound salty man. Don't hate cause them sundowns can't take it.
---------- Post added at 11:24 AM ---------- Previous post was at 11:23 AM ----------
I clamped 12k on my left nut.
Sq subs same setup gained like 2 db over his DD 99's what ya got to say hugger boy
Place 5k watts on a 50hz sine wave and see if a DD Z will last 5 minutes.
Same concept except in my post it was for dynamic power aka music.
Short bursts of even 3k wont kill a hdc3 either, but id stay in the 2-2.5k
Burps are stupid. No salt
Just means the enclosure was more suited for the SQ. tar tar
---------- Post added at 11:30 AM ---------- Previous post was at 11:29 AM ----------
Noloud said DD z rated at 1500-2k coil
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
ekah
ekah
hawaii
ekah
    Jun 1, 2024
    May 31, 2024
