Why does my new sub sound like its "maxing out"
  • 4
Jlaudioeh
canada
I have a new JL audio 13.5" TW5 Shallow driver in an enclosed box. Im powering it with Alpine MRP-M350
Class D Monoblock Amplifier. It sounds fine at low and mid range volume but when i turn it up it sounds like its "maxing out" The sub should be able to handle twice what that amp can put out.....Any ideas?
You might be clipping it into distortion. Maxed out = bottoming out where the voice coils are slamming against the magnet and losing control hearing a lot of mechanical noise. Distortion from clipping just sounds like cr*ap. You either need more power if you expect more out of it. It could also be you are expecting too much out of a shallow sub. Try repositioning the subwoofer, subwoofer placement can actually make you a lot louder depending on where you put it.
Amp apparently tops out at 350W RMS @ 2ohms, sub is 600W. Could be that i am "clipping". I will try playing with the gain but more than likely I am asking too much of the amp
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
349
Thanks everyone for the replies! Like I said in my first post I’m not wanting to be loud, I just would like to have a little extra bass.. I like...
12
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
968
Jlaudioeh
Jlaudioeh
canada
Jeffdachef
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
