2005 Scion xB SQ build (rebuild) Hybrid Audio/Alpine
Shoulda got AT bruh bruh. I was thinking that having those 3inch drivers bouncing off the dash like that could cause issues on the higher fequencies, also curious as to how they will play out with the tweeters there
You mean bouncing off the windshield? I had my 1" mounted there and I had no issues, also the stock 3" were mounted there as well. The stock system in these xB's were not all that bad out of the box.
I will hopefully get to power it up this weekend........ I hope.
You gonna run some oldschool kicker ss? I had my tweets like that and I was given hell at the meca comp for it
No Kicker (Although I do have a pair of 3" Resolutions) I am running a full Hybrid Audio driver system including the sub, We shall see about the tweeters, we have a Honda Civic with the Imagine tweeters set up just like mine in the pillars and so far no problems, the Civic has some of the best width and depth and image I have heard in a car without the use of TA. Just a few hours of tuning and tweaking have gone into it as of right now and it has scored pretty high in rookie.
You should hear my Fit. Its still a work in progress but I dont use any TA and it is by far the best as far as stock locations go. I was more or less joking about geoffs amp ahah
:Update:
Although the photos do not show a lot of "progress" making this enclosure has taken quite a bit of time and it is pretty close to being finished.
This is my first time working with fiberglass, a good friend of mine has taken the time to show me the basics of this process and to be honest I have no idea why I was so worried about working with fiberglass. For the most part it is a pretty simple process that takes a lot of time!
What you see going on here is the stock Scion xB foam storage bin being wrapped with fleece and used to make a mold for the base of the sub woofer enclosure.
This took about a gallon of resin so far and I still have quite a bit of coating to do to get it solidified enough to support the pressure of the i10SW.
Anyway here are a few photos to gawk at. I will be applying a coat of resin every day on the outside and inside of the enclosure.
Enjoy!
Small but big update, its also been a minute since I have posted here in this thread, no photos yet but the front stage is in and up and running. Got it all dialed in and put it on the RTA and smoothed it out. All i have to say it wow, softball sized center stage, width and depth are out past the a-pillars and on the hood. No solitified sub yet since the false floor is taking more time then I thought it was going to.
I Got to double check these numbers but i believe this is what i have the x-overs at.
8" Sub 40-1hz 30db 20hz +6
6.5's are 40-100 24db
l3's are 100-8k (12db)
1" are 8k-^ (12db)
So for my first show with this being tossed together for points for a x2 show this last weekend I got a pretty good score 217.
But I have to say that a 217 for maybe 3 hours of tuning and 1 hour doing RTA work that I got a very respectible score.
I went a head and put in my DD1508 that I use for testing amplifiers it is in a 1cf vented enclosure tuned to 35hz. I had it crossed off at 40hz with a 30db slope with 20hz +6.
As far as the L3 xover points this was suggested by Bill Pleasent of Team Hybrids who is my neighbor and has lent his hands and ears to this build. The L3's really sing nice and blend well with the I6.5's. I am thinking I might ditch the tweeters and try to run just the L3's. I wish I would have taken a photo of the RTA graph it was pretty impressive.
These Gen1 xB's have amazing acoustics for a good front stage with great depth and image with that windshield angle being as steep as it is.
Anyway here is my score sheet. I cannot wait to get the back done and get a good week or more of hard core tuning and RTA work in.
Nice report card. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Getting more left stage width can be tricky with those locations. You want left channel info to reach the left ear first and get some shadowing to the right ear.
Keep the pics coming.
Thanks, I will be doing a few hours of tuning tonight in preperation for a show in Canada this weekend.
Once I start working on the false floor again I will post some more photos!
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
745
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
https://www.sonicelectronix.com/ci95-2005-buick-lacrosse-wiring-harness-to-install-a-new-car-stereo.html?sort_order=price_asc lots of options...
Can anyone in here participate in a short interview I am doing for school about the installation of a Kenwood DMX4070S in my 2005 Ford Expedition...
I have a 2012 Toyota 86 (Australia), with the standard factory fitted head unit. It has served me well over the years. All of a sudden the...
Shinju
Shinju
Seattle
Shinju
    Jun 1, 2024
    May 31, 2024
