Another Installer- North Jersey
DMP
Hi, im new here, but not new to car audio. I used to work at a very high volume dealership installing and also did side work on the side.
Here's a list of some of the things I can do.
Radio (Aftermarket, Ipod, Navi..etc.)
Amps
Custom Built Subwoofer Boxes (MDF)
Interior Lighting Upgrades
HID's
Foglights
Alarm
Remote Starters
Keyless Entrys
Manual to Power Window Conversions
Manual to Power Lock Conversions
Other Modifications (Disable Daytime Running Lights and/or Automatic Lights, etc.)
Repair Services (available for certain things):
Non-working Aftermarket Head Units
Alarm and/or Remote Starter (Problems, programming new remotes...etc.)
Electrical Problems
I by all means don't mean to take away any business from anyone else on here. I figured maybe I could offer other installs other than just car audio. Sorry in advance to any installer reading this. And thanks for reading.
Here's my audio build im working on. Built a box to go into a GMC Sonoma (standard cab) which is basically the same as the Chevy S10. If you know much about them, then you would know about how little space they have behind the seats.
Here's the box I built.
Carpeted and finished.
Amp rack built to house 3 amps.
Added these bars to protect the subs. The seats fold back really close to the subs. (no taking chances here) And no the bars arent slanted. Im not the best picture taker. lol
Im almost done with it. So ill take a final picture when im done.
Here's something else I did. I converted the truck from manual window to power windows. It left a hole where the window crank used to be in the door panel. Well....its a nice place to install a tweeter! No more hole. And I cut out the stock plastic speaker grill and installed metal grills in the panel to match the tweeter. A set of components were installed in the truck. Heres a picture.
Did this too. Built the box and wrapped it with red vinyl to match the interior. This went into a BMW M3.
What's ur price on building boxes
It really depends on the options. Whether its a single or dual box, carpet, vinyl...etc. The boxes start from $30 and up. If you want a specific price on a box, let me know more about the box and ill PM you a price.
Also, I build them with 3/4" MDF. But if weight is an issue for someone, I can build them with 1/2" MDF.
More pics. This went in the truck that has the Rockford system. Pioneer head unit and also installed a white HVAC gauge trim. I had to custom fit the pocket under the head unit. Took some work, but I pulled it off.
White face gauges in the same truck
That looks like the same headunit I have.
ub-3200, nice deck for what it is....
OP nice work //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
DMP
DMP
North Jersey
DMP
    Apr 28, 2024
    Apr 28, 2024
